Hi, I'm not too up on wheel fitments etc. so I hope someone can help!
I have been offered superlites 4 x 100 PCD 6j with an offset of 10. Will these go on my K11 ok or will I have problems?
Last Edit: Mar 6, 2014 17:11:44 GMT by renofan
'86 E30. '86 E28. '92 E32. '97 Laguna. '98 March. '00 A4. '05 Focus.
Anyone?
Buy and try ud flog them easy with that pcs if they don't
Hmmmm.....that sounds a good idea!
i don't think so, k11 takes ford/pug wheels, have saw a lot rallying with RS wheels on...
4x100 may fit your e30 though!
RobinJI
i don't think so, k11 takes ford/pug wheels, have saw a lot rallying with RS wheels on... 4x100 may fit your e30 though! K11's are definitely 4x100 not 4x108. They'll sit further out than standard wheels, so may cause arch clearance issues needing the arches to be rolled. I don't know how much movement you can get in a micra arch before it becomes an issue though.
Don't forget the centre bore size to, the Micra is 59.1mm - although you can get adaptor rings. And yes, Micra's are 4x100.
Peugeot 307sw - Suzuki SV650S - MX5.
