If it was a collapsed air inlet it would be black smoking though wouldn't it? Did you set the valve clearances? Is it possible it could be a problem with the box rather than a lack of power from the engine?
MonzaPhil
As its a Land Rover, any symptoms and causes are possible. When the boxes go, normally you just lose drive. I guess checking the kickdown linkage would be a good idea.
Sent from my HTC Desire C using proboards
This is now a clicky linky!
bl1300
Its kicks down fine and changes through all the gears. Its not that the box is in the wrong gear theres no power. Top intercooler hose is new and pressurises when you rev her up. Without load it will rev freely and on the flat or kicked down from speed it will rev all the way up to the governor at 4500rpm.
Current fleet.
MonzaPhil
Ha, you're not making this any easier!
Running on pump diesel not bio, veg or Tesco?
Still almost sounds fuel starvationy.
bl1300
Oh by the way plan B is buying a rotten disco that runs nicely and to make one good one out of the two.
Current fleet.
bl1300
Running pump diesel normally Shell i've never put supermarket fuel in it as the nearest one with a petrol station is about 25 miles and at the moment I don't dare drive it that far. I'm starting to wonder if the new lift pump isn't working and its just running on the injection pump, it wouldn't suprise me i've had plenty of new parts fail within days.
Current fleet.
MonzaPhil
Not impossible is it! Is the pump operating arm the correct side of the cam?
I have a spare 300 disco.... And a 200.....
bl1300
Not impossible is it! Is the pump operating arm the correct side of the cam? Sent from my HTC Desire C using proboards I will have to check that as it was previous owner that installed the new lift pump. I've been assuming it to be ok because it's new and pumps fuel using the priming lever Sent from my V370 using proboards
Current fleet.
i had a 300tdi with the exact same problems, lack of power was down to a cheap airfilter. just wouldnt let enough air through when under heavy load. the bad starting was resolved by putting a new alternator on! i had already changed glow plugs/starter motor/fuel pump/fuel filters with no joy!!!!!!
Mar 11, 2014 10:30:26 GMT
Possible dead MAF Unplug the wiring to the MAF, and short out the outer pins (1+5) with a paperclip. If it brings it back to life, the MAF's dead two solutions: 1) buy a new MAF, at a silly cost (and it'll still die a few years on) 2) leave the paperclip in - and enjoy a bit more power to boot
Mar 17, 2014 17:15:38 GMT
It's not the EGR valve is it?
bl1300
Mar 17, 2014 18:26:51 GMT
Not the EGR already been blanked to rule it out. Haven't had a chance to look at it much recently and for the time being ive just parked it up and am using the "spares" car.
Current fleet.
Mar 18, 2014 19:56:39 GMT
Life without spanners is no life!
Rover 414 SLI
