So, I may have had a bit of fun in the car today and now the clutch is a little unwell. Great for testing the wobbliness of a jelly when you pull away though! Still, I had planned to replace it anyway. Easy enough, jump on Euro Car Parts, put in my registration and pick my clutch. Except they list three, two have 22 teeth and one 20. I assume they mean splines? Without removing my old clutch from the car how can I tell which one to buy? It's a (August?) 1991 1.6 car.
Cover Diameter(mm) 200
Description 3pc Kit inc bearing
Diameter [mm] 200
Diameter 1 [mm] 200
Diameter 2 [mm] 200
Extra Information Kit 3 Pieces (cover & plate & bearing)
Number of Teeth 22
Plate Diameter(mm) 200
Supplier Nr 3000824601
Weight [kg] 4,65
Engine Code B6
Fitted Quantity 1
www.eurocarparts.com/ecp/c/Mazda_MX-5_1.6_1991/p/car-parts/car-transmission/clutch-and-associated-parts/clutch-kit/?641680140&1&dfe17119f1fe9c547fb83a569cc97a6b1d4c5e8c&000069
Diameter [mm] 200
Diameter 1 [mm] 200
Diameter 2 [mm] 200
Number of Teeth 22
Weight [kg] 4,65
Engine Code B6
Fitted Quantity 1
www.eurocarparts.com/ecp/c/Mazda_MX-5_1.6_1991/p/car-parts/car-transmission/clutch-and-associated-parts/clutch-kit/?64168014J&1&1524a0b693f5e5b2135a5d51b12dfdfd9b2877ce&000069
Diameter [mm] 200
Number of Teeth 20
Supplier Nr 3000257001
Fitted Quantity 1
www.eurocarparts.com/ecp/c/Mazda_MX-5_1.6_1991/p/car-parts/car-transmission/clutch-and-associated-parts/clutch-kit/?64168016J&1&cd53dd2a64efb1f8510dc57bcf98ae4223b55691&000069
Diameter [mm] 200
Diameter 1 [mm] 200
Diameter 2 [mm] 200
Number of Teeth 22
Weight [kg] 4,65
Engine Code B6
Fitted Quantity 1
Diameter [mm] 200
Diameter 1 [mm] 200
Diameter 2 [mm] 200
Number of Teeth 22
Weight [kg] 4,65
Engine Code B6
Fitted Quantity 1
Diameter [mm] 200
Number of Teeth 20
Fitted Quantity 1
