mclellanmac
Hand me the hammer and the WD40
Mar 15, 2014 21:15:58 GMT
Help me please guys!
I've got an R129 mecedes SL, and I'm getting a rather alarming steering wobble, I've had the wheels balanced, but it's still the same, I've also replaced the steering damper, but to no avail!
It seems worse without the hard top on, it's too serious to put down to scuttle shake, has anyone got any ideas? I've been told the ball joints etc are all alright, soooo I dunno!
Any Mercedes experts out there got any idea?
Thanks very much guys!
Mercedes 190e, Lovely
MK4 Golf GTi 20v Turbo, Dull, but always works!
Mar 16, 2014 19:35:38 GMT
It's probably the idler pin bushes ,if you follow the track rods in you will see it hiding there . its an unfortunate byproduct of having the steering box on on chassis leg and the car being wiiidde , My s class has exactly the same wobble at speeds of 50 to 60 mph when braking and makes my twitch and do a pac man impression Cheap to fix as you can get the bushes on ebay dirt cheap
mclellanmac
Mar 16, 2014 19:48:47 GMT
Thank you very much, I shall investigate!
Il be honest it's really ruining the car for me, I love it, but it makes me not want to drive it, fingers crossed it is an easy enough fix
Mar 16, 2014 21:39:57 GMT
Every Merc bar my vito has had that pain in the backside wobble ,for £20 it's worth doing the idler pin bushes anyway coz it cant make it worse .
mclellanmac
Mar 16, 2014 21:45:49 GMT
I've read a couple of bits online does seem to cause a similar problem to the one I'm having
Can you recommend a good place to buy the bits? Can't see them on the EBay
Mar 16, 2014 22:55:46 GMT
If they aren't on ebay (surprised ) GSF and eurocarparts do them but you might be surprised how cheap they are at the merc stealership ,ones for my w140 were about £15
mclellanmac
Mar 16, 2014 23:26:40 GMT
I can't see idler pin bushes on GSF, do they go by a different name?
Mar 16, 2014 23:37:06 GMT
All the ones on ebay are from gsf and i searched for idler arm bushes .
mclellanmac
Mar 17, 2014 17:18:24 GMT
Mar 17, 2014 18:24:55 GMT
Last Edit: Mar 17, 2014 18:26:17 GMT by dubmeister
mclellanmac
Mar 17, 2014 19:03:44 GMT
It's a 1996 sl280
Mar 17, 2014 20:43:57 GMT
The one i listed above fits a 96 320sl which is a bored out version of yours i think so may be worth searching for that part no or car and see what you can turn up in the uk
mclellanmac
Mar 18, 2014 17:54:38 GMT
Mar 18, 2014 19:34:50 GMT
No but this is a pic of the bit you are after off my 500sel ( no 6 )
Last Edit: Mar 18, 2014 19:35:17 GMT by dubmeister
Mercedes R129 steering wobbleChasR
@chasr
Club Retro Rides Member 170
Mar 18, 2014 23:42:00 GMT
I would be looking at the steering idler and balljoints.
At what speed does the wheel wobble? Are you on standard wheels?
mclellanmac
Mar 19, 2014 14:30:38 GMT
It starts really badly at around 60, but reduces a little at about 80
It's not it's on some 18 inch AMGs, I assume they are reps
Mar 19, 2014 23:14:19 GMT
To be honest it's almost impossible for us to diagnose your car we can only point you in the right direction then help out when you're there It could be wheels and tyres ,dodgy made discs and hubs out of balance ,upper and lower arm bushes ,front and rear by the way ,then you have balljoints ,track rod ends ,idler arm bushes ,steering rack may need adjusted and so on A little bit of wear on any or all of these parts could give the symptoms you have described .
Best thing you can do is get under the car and start levering stuff to look for wear that is obvious and do those bits first
Club RR Member Number: 160
Mercedes R129 steering wobbleRich
@foxmcintyre
Club Retro Rides Member 160
steering rack may need adjusted and so on Steering box, but yea.
Mar 20, 2014 13:21:06 GMT
Correct ,god knows why i typed rack ,lack of sleep probably Luckily the rack is easy to adjust ,just a 6mm allen key and suitable sized spanner (17mm i think)
