IHI VF23 from WRX STI. This turbo has no play, the blades are in mint condition. No usual cracks around the wastegate.
This is one of the largest roller bearing turbos fitted to the STI using the larger P20 exhaust housing. The housing has also been ported to minimize any increased lag
This is from a classic STI running 340bhp. Unfortunately I haven't tested it to verify this
One exhaust housing stud would need replacing.
Please ask if you have any questions
Taken from Subaru website;
This turbo is considered a great all-around turbo. Like the VF22 it utilizes the largest P20 exhaust housing. This housing is mated with a smaller compressor housing of the of the VF24. This turbo is considered optimal in applications with range from mild to slightly wild. It does not have the same top end power of the VF22, but spools up significantly quicker. This turbo will start to come on boost at 3000 rpm and is capable of 20 psi @7000 rpm. Expect to max out the VF23 somewhere in the 300-350 hp range.
www.ebay.co.uk/itm/201053787212?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
