DESIGN CHANGE
Due to a couple of factors, I have decided to make a minor adjustment to the repair kit. It will in no way affect its performance, but should increase reliability. Instead of two M12x1 fittings, there will now only be one, and three of the M10x1 fittings. The M12x1 adaptor has also been replaced with another M10x1 adaptor.
The main reason behind the change, is that the M10x1 fittings are available in a "long" format, and therefore allow a better seal to be made. The M12x1 fitting is still required for the Power Steering Pump.
Up for your delectation today, we have a CUSTOM designed and made replacement for the Power Assisted Steering Hose on the Citroen Xantia.
This is guaranteed to fit as a direct replacement for the rusted and corroded one your car currently sports. I know this, as mine is doing so at the moment!
Supplied in the package will be;
1x SAE 100R2S-AT 2 Wire Reinforced Hydraulic Hose complete with Swivel fittings.
2x Custom machined M10x1mm fitting
3x M10x1mm Long 3/16 Fitting
1x M12x1mm 3/16 Fitting
This neat little package will have your power steering and LHM leakage sorted in no time at all, being a direct replacement.
The price I hear you scream? Delivered to your door for £40!!
PLEASE NOTE
THESE ARE MADE TO ORDER IN HOUSE AND WILL TAKE APPROX. 1 DAY TO MANUFACTURE!
NO FITTING INSTRUCTION ARE SUPPLIED, HOWEVER, THE PROCESS IS STRAIGHT FORWARD!
NO KUNIFER/COPPER PIPE IS INCLUDED BUT CAN BE SUPPLIED AT EXTRA COST.
