Hi guys, trying to help my brother diagnose his Fiesta's indicator issue.
So basically his front right indicator light doesn't work at all, tried different bulbs and no change. If the right indicator is put on, the rear one flashes quickly and if the hazards are put on the rear right indicator flashes normal speed, but no flash from the front right at all.
Put my circuit tester on it with the hazards on and the bulb holder is giving out a reading of 3 volts.. so I tried cleaning up the earth contact for the indicator where it meets the car body as it was on a painted panel. But no good.
Any ideas on where to try next? the wiring diagram seems to show that the power for all the right hand side indicators can be traced back to a single point, any one know where this is?
Thanks in advance
Thanks in advance
