Mar 30, 2014 15:27:53 GMT
I bought this 1980's accessory off eBay called a cal custom performance timer it's new in the box but missing the magnetic speed sensor I have the magnets that fit to the prop shaft, it's just missing the electronic sensor seen in pic below, does anybody know where can I get a suitable sensor from? Thanks
Mar 30, 2014 18:29:53 GMT
I'd try it with any old sensor and see how it goes.
You should be able to see whether it wants 2 or 3 terminals on the sensor and just get something similar from a motorfactors. In the past my local friendly motor factor has let me go into their storage area and look through all the sensors they had until I found something I liked the look of.
The other thing you might consider is splicing it into the speed sensor on the car you are fitting it to. A lot of them read from the gearbox although more modern cars will have x4 wheel speed sensors. Some have both.
As it's a universal fit device so you should be able to calibrate it.
squonk
Mar 30, 2014 18:36:21 GMT
Knowing how many wires the original probe had may help in getting something that is compatible. If it has three wires it is probably going to give a TTL square wave pulse output. If it is two wires it is probably a zero crossing sinusoidal output. Do you have a wiring diagram for the system?
Would it be possible to use one from a bicycle speedo?
Mar 31, 2014 19:20:56 GMT
Last Edit: Mar 31, 2014 19:22:04 GMT by vauxviva
RobinJI
Mar 31, 2014 20:18:38 GMT
B5 Passat's use a 2 wire sensor for the speedo which might be worth a look.
I thought about bicycle sensor but would the prop shaft not spin too fast for sensor to pick up? In theory no because you set them on a trial and error basis (the ones I have used need to know the bike wheel size so calculate the speed from that so you would set it as a very small wheel size) In practice I'm not sure because I have only used them when the magnet is on the hub or wheel on motorbikes and cars , On cars its not 100% accurate that way but it doesn't have to be legally.
