Shed/garage/car clear out due to a house move so everything must go. Collection from Tunbridge Wells or might be able to sort collection from Hertford or Billingshurst. Otherwise prices are plus postage unless otherwise stated. Will consider offers.
Maniflow RC40 Centre Single Exit, 2” inlet, 2” rolled tip out. Very good condition. £SOLD
Stainless 2” centre section. £10
Front and rear windscreens with factory green tint. £40
Ignition switch. As new, untouched condition. £10
KYB front shock absorbers, as new <3000 miles. £SOLD
Steering column cowl in black, good condition. £10
Genuine Sportspack arches in good condition, in white. Some studs missing and will require a respray. £50
2x Standard sealed beam headlights. 1x Wagner, 1x Unipart. £5 ea
Original dizzy weathershield, the bottom fixing has been cut off but it doesn’t affect its use. £10
Master cylinder. £20
Twin clock cowl. £5
Mk1/2 boot lock. £15
1x Chrome door handle. £5
Pair of door pockets, good condition. £10
Chrome grille. Grubby and needs a clean, also two slightly bent slats, could be pushed back to be barely noticeable. £15
Ducellier coil. £5
2x Mechanical fuel pumps £10 ea
Alloy inlet mani, one corner has come off affecting the stud hole as can be seen. Useful to someone? £5
Sunroof frame. £20
Pre-engaged starter motor. £10
Twin clock cowl. £5
Ducellier coil. £5
Sunroof frame. £20
