Tried to change the fuel filter on my Saab 900 last night and had a nightmare. Cutting to the chase, I managed to put a kink in the plastic fuel line which split when I tried to straighten it. The fitting is a barbed banjo fitting which the plastic line was pushed onto (presumably after heating the pipe at the factory). I can't refit the banjo into the line, partly because I can't get the plastic warm enough to be flexible and partly because it's too short now anyway. Options:
1. I can get a whole new line put on my ends but this means removing the whole pipe and I can't get to the hose place until next week.
2. Other suggestions offered to me are to use a few inches of rubber fuel pipe and use a jubilee clip on the banjo fitting and slide the plastic line in the other end with a couple of jubilee clips around the rubber to clamp it. This option is quite appealing because I have the stuff lying around to do it but makes me slightly nervous at the same time.
3. A Saab specialist says he can supply a banjo with a short piece of plastic hose attached and a fitting to join to the existing pipe but wants £30 + p&p for it.
Should I do without the car for a few days and go with 1, go quick and dirty with 2, stop being tight and go with 3, or do something else?
