Hi I'm thinking of putting pvc (probably not the correct material, but it is fuel safe) fuel lines on my project and i have to use some 1/2" to 16mm threaded converters. What type of thread sealer can be used with Ethanol?
Cheers
Geoff
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
Just to clarify..the fittings are steel.
cianha
aka VDubbin
Teflon?
Loktite do a liquid thread sealer made for fuel taps and such. Expensive but good.
Remade In Australia thereimaginarium.com.au
Good old Red Hermatite
Paul H
I'd go with the Loctite solution. Similar to threadlock and does a similar job but I found that to be the best solution when I did my DIY nitrous conversion. That held gas at high pressure! (like 1000psi) Will eaisly handle liquid at fuel system pressure.
Cheer guys! will investigate the Locktite option tommorrow, any specific product numbers?
