so i have in issue with my instrument cluster dash in my mk2 golf cl 1.3 (1985 ?) it has two wiring plugs and a analog clock with the speedo having some sort of a fault when i need to have the driving lights on to be able to see all the flicker lights and battery /oil / mainbeam lights also now the fuel gauge and temp gauge are not working got this code of the cluster foil 54401 19800 along with some other codes like 533 957 033 j and 601 037 3030 don't kno if any would help but would really appreciate some advice on weather i could just straight switch it with a working rev odemeter cluster and speedo dash as long as it has the two plugs or would need something eles @?
any ideas or theories all comments gratefully received as i have no idea many thanks
