Apr 11, 2014 17:34:12 GMT
Hi guys, I recently fitted a recon head on my 1990 1.4 CVH escort van, ever since then it's had a nasty misfire and I've done everything I can think of, fitted new plugs, leads, rotor arm (in December), coil, electronic ignition module, new dizzy and cap, made sure the vac pipe wasn't blocked, checked for air leaks, cleaned the engine earth strap, checked that the leads are in the right order, checked that the cam timing is correct, all to no avail. Any thoughts or observations would be very greatly appreciated.
Mike
Apr 11, 2014 18:41:23 GMT
try taking each lead off in turn and see if anything alters. THe one that doesn't alter anything is the cylinder at fault. I had a faulty valve once which had a burr on the top. Had to file it off and the car was good as gold again
MK4 Ford Escort XR3i - Standard MK6 Ford Escort GTi - Track Car
Apr 11, 2014 19:13:32 GMT
thanks I'll try that tomorrow
rodney
Apr 11, 2014 23:39:55 GMT
have you checked the cam timing?,.
Apr 12, 2014 16:29:42 GMT
have you checked the cam timing?,. Do you mean at the belt end? if so than yes, it looks to be spot on
rodney
Apr 12, 2014 17:06:41 GMT
is it carb?? as blocked jets cause a miss under load,.
Apr 13, 2014 15:20:33 GMT
is it carb?? as blocked jets cause a miss under load,. Yes it's a carb. It's missing at idle as well, sorry should have said that
mk4 escort van missfireChasR
@chasr
Club Retro Rides Member 170
Apr 13, 2014 19:20:18 GMT
Without trying to be the bearer of bad news I would try and get a compression tester and check the compression. Prior to that, I would isolate the cylinder which is misfiring by pulling off each HT lead one at a time as MattXR3i has said. If I am a betting man I reckon it is either a camshaft issue (they are no stranger to cam wear if oil changes have been negleced (how often do you change the oil and how often was it changed prior to that and with what oil?)) or a burned out valve (putting a teaspoon of oil in the affected cylinder after doing a compression test should isolate this. Of course it could simply be a faulty spark plug .
Apr 15, 2014 13:35:31 GMT
Compression test is a very good idea.
Apr 15, 2014 18:02:51 GMT
Thanks for all your input, I'll try and check all that out this week and get back to you
