Right I have just bought a full set of the following shocks for my MK3 Cortina: but from Rally design.
I have had a fiddle with them to see what clicker setting to adjust to on the front, Gaz recommend to put them in the middle setting, but one shock will not move at all by hand and the other can be moved. So I adjusted them until they both felt quite similar to each other ( not accurate I know but just a rough idea ) then counted how many clicks it was, and was surprised to see that one is at 8 clicks and the other is at 24, surely that huge of a gap is not right?
I have the dyno charts here for them if anyone can make head or tail of them, I can upload some pictures of the charts if it helps.
I don't want to fit them until I get this right and that one of the shocks isn't faulty. I had already fitted them to my car but had a problem with the threads on the lower wishbones, so had to remove them again. Which means if one is faulty, I'm not sure if Rally design will take it back.
Please help someone, I'm really struggling to get my head around this. I've never had adjustable shocks before so don't know if any of this is normal.
The rears are only two clicks apart by feel which I would of thought to be more like it.
Thanks,
Adam.
Thanks,
Adam.
