pork
I need my rev counter to work (shift light controls supercharger clutch)
Ever since I've fitted injection and ecu, the rev counter don't work
Any suggestions?
Any way off testing whether I'm actually getting signal from the ecu?
andyborris
Which ECU?
On many you can use one of the unassigned outputs for this.
pork
It's a redline developments ecu (kdfi)
I'm using the dedicated rev counter output, it's all enabled on the software too
pork
So is there a couple of tests I can do?
was the original rev counter triggered from a single coil? and its now running a waster spark coil?
pork
Yeah, was on carbed engine, single coil
Now coil pack ignition
I made a thing for my 205 and a mates 205 that picks up the ecu's earthing signals to the coil and sends it to the original tacho, I have enough bits here to make many more.
pork
Ideally I'd like to use the tach output with the ecu So just need to test to see if output actually works
my mate is using a DTA ecu and myself a Bosch motronic, there wasn't any other way to do it other than get a speedo head from a newer car that will accept the signal.
Last Edit: May 8, 2014 20:01:52 GMT by welshpug
RobinJI
andyborris
If it's a aftermarket tacho (and it sounds like it is, because of the shift light), you may need to change it's settings. If you're using a wasted spark set up, the tacho may be seeing too many signals.
If you can't reset the tacho, then maybe a filter circuit is needed as above.
And on some ECUs, you can configure a output to switch at a certain rev limit and use this to drive the supercharger clutch.
pork
The relay coil one looks ok to me
Is it just rhe coil from an ordinary 5 pin relay?
Yes, worked for me. I had to mess around with the circuit a bit and try a different value zener diode but it did the trick in the end. That was with an old Smiths RVC tacho in a Triumph.
Nick
pork
Cool
So a trip to maplins tomorrow
So need a:
5 pin relay Transistor 1k resistor
That right?
Last Edit: May 8, 2014 22:14:04 GMT by carat 3.6
RobinJI
Cool So a trip to maplins tomorrow So need a: 5 pin relay Transistor 1k resistor That right? Looks like it. Let us know how you get on. I'm kind of interested as I've got a nice smiths rev-counter spare that I'm debating using in the MX-5. Hence why I rememberd that post in the Lancia thread. (Well, that and the Lancia thread being in my bookmarks because it's a good read.)
pork
May 10, 2014 16:43:51 GMT
All sorted now..."............turns out the ecu outputs were back to front in the instruction booklet!!
