if you already have the polybushes wouldn't it better to fit them and make both ends of the 'chassis' the same i.e same stiffness?
Chances are if the rear bushes are the originals they will be 'soft' by now....
Just a thought .... epic weldathon though !
No I will do it! It's just currently iv not got the spare time in the workshop to pull the rear subframe off and rebuild the rear shocks! It's still got a small amount of welding left then it's xomplete for its MOT
So all this work has been done and now it's ready for its MOT That's the wheel arches painted up And my modified wheel arches that won't Rot! Just waiting for the MOT now
Apr 15, 2015 12:29:53 GMT
Getting the tracking sorted before its MOT (Which it passed)
Apr 15, 2015 12:30:53 GMT
Gave her a wash after driving with the roof off for the last 4 days in the beautiful sun!
Apr 17, 2015 14:53:15 GMT
Looking great and well done on MOT pass. Making me feel very guilty about my progress or lack of!
no car, no garage, but the garage is coming oh yes!
Apr 17, 2015 17:45:27 GMT
Cracking little car, I need to get my mgf finished! You can't be flying around the country roads with the roof off
Yea loads of progress I now no she is solid at the front! I still need to remove the rear subframe clean that up and weld under there! (And also poly bush it!) And fully was oil (maybe wax pickle is what I should do) But for now progress is good! *fitted my rear strut brace* Now sometime when I drive I can make my spine hurt! Also driving with the roof off! We have experienced some great weather these last few weeks and the roof have been off loads! But I never get pictures I think it's because I'm out enjoying driving to much!
Jul 13, 2015 20:07:01 GMT
Another oil and filter change done! Good for a few more thousand miles! Also had the air con pressure tested today! It dropped about 3psi in 30mins which is apparently acceptable then it was topped up took a full 650 grams. Not sure of it was 650 or 750 so we went for 650 to be safe! It now works but it's not exactly ice cold maybe on a longer run it would be better? Anyone else have working air con?
Aug 10, 2015 19:39:19 GMT
So the last few days I have spent cleaning up my alloys and painting them! This is the end result! With some rim tape added
For a while now iv had a small oil leak at the back of my camshaft housing that leaks on to the exhaust manifold. Then I get some smoke and a nasty smell of burning or burnt oil! Song purchased the gaskets at Suzuki for 18 quid each and under took the mammoth job that is! First I removed the cambelt. The the camshaft housings. End result of a hard afternoons labour! Then whilst everything was off I have it all a small lick of paint! To take away the rustic look of rust and ageing engine parts! Then after it had all dried. I slowly wrestled it all back on! Except for one of my coolant pipes which unfortunate was so rusty and flakey that when I started to remove the rust it actually has serval small wholes in it! So currently I'm searching around for one. Then I can finish the job . Top up coolant engine oil and run her up check for leaks and that everything is all ok! So far this is the slightly new look. Without my shiney bits added!
Feisty looking little bu g g er
Last Edit: Aug 31, 2015 7:32:49 GMT by hessu75
Ford Capri Mk3 -79 2.9EFI turbo, summer ride Ford Sierra 4x4 STW aka "GABy", winter ride Kawasaki ZX14 Project 2.9 EFI engine for the Sierra 4x4.
Aug 31, 2015 17:23:27 GMT
One day it may well be!
Last coolant pipe painted now and ready to fit and rebuild
Sept 4, 2015 12:36:11 GMT
Last coolant pipe painted now and ready to fit and rebuild That's some overspray you got there!! :LOL:
Sept 4, 2015 12:43:44 GMT
Hahahahhaha I thawt it'd be funny to photo it there
Sept 4, 2015 19:52:25 GMT
Had one these a few years ago. Great cars. The aircon never worked or ours either.
Still got a few Capp bits kicking around, standard steering wheel, clear side repeaters and maybe a few other bits. You can have them if you cover the postage?
Best Served Chilled
Sept 4, 2015 20:03:31 GMT
Woow woow back track my good friend ! I have working air con... Now Ice cold! Don't notice the loss of engine power either when it's on! Hahahahahahah......nawt You'll have to fill me in on what you have in sure if I don't need it I could find someone who will! Thanks very much Ed
Sept 5, 2015 18:33:42 GMT
Work complete and engine is running fine now! No oil leak as of yet! Just need to reseat the dip stick as that's leaking.
