breng
May 15, 2014 20:49:59 GMT
I adjusted the timing in my SD1 VDP EFi - it was struggling to turn over, as if the timing was too far advanced.
I set the timing to 8 deg. BTDC but noticed that the mark on the pulley kept moving - i noticed the engine running differently when this happened.
Dodgy centrifugal advance or a bad no 1 lead?
Thoughts please.
sowen
Club RR Member Number: 24
Ignition questionsowen
@sowen
Club Retro Rides Member 24
May 15, 2014 21:24:16 GMT
Sloppy cam chain letting the dizzy wander? Worn distributor shaft? Loose vacuum advance?
Ignition questionChasR
@chasr
Club Retro Rides Member 170
May 15, 2014 22:06:23 GMT
What Sowen said.
You could try another dizzy, but chain wear has be known to cause timing scatter on Rover V8s as well. I guess you could rule out the vacuum advance being iffy by disconnecting it.
breng
Chain set is brand new - an all steel item.
If it was that, the moving timing mark would not be intermittent - it always moved back to the pointer, which makes me think it is a dizzy broblem.
breng
I had a suck on the pipe that attaches to the vacuum unit - i could see the mechanism moving.
sowen
@sowen
May 16, 2014 11:44:43 GMT
Is there any 'free' play in the advance mechanism, before the vacuum and centrifugal weights give resistance?
taurus
May 16, 2014 19:33:12 GMT
Or play in the dizzy shaft? That will alter the points gap thus throwing the timing around.
bortaf
May 17, 2014 14:11:31 GMT
did you set the timming with the vacume advance disconnected ? IME it's usually a worn dizzy bearing making the timming scatter but you never know .
R.I.P photobucket
