breng
May 17, 2014 17:00:08 GMT
While adjusting the timing on my VDP EFi i noticed that the fuel gauge apperared to have died.
One minute it registered fuel, the next thing the needle was at rest.
Any ideas?
May 17, 2014 17:31:33 GMT
To test whether gauge or sender you simply earth the sender side and the needle should go to full. If it does that then you know either sender or wiring to sender / connections. If on the other hand needle doesn't move then that indicates faulty gauge or power supply to gauge. Obviously this is "old fashioned" analogue gauges Paul h
May 17, 2014 19:32:41 GMT
Obviously this is "old fashioned" analogue gauges Paul h These are not "old fashioned" they are "traditional". Digital are "new fangled" Colin
