quasimoto
I started out with nothing and i have still got most of it left
from choice over the years a ooh argh klaxon horn gives much amusement for the money genuine dixie horns i would start looking in USA for something authentic or closer to home wanted ads on rods n sods and of course on our own wanted section laying in a garage somewhere who knows ?
Mad As A Box Of Frogs
cjhillman
May 23, 2014 12:00:43 GMT
I'm waiting for them to turn up (amazon one day delivery thing) Not expecting much but i've been looking for ages and just want some cheap fun.
I'm wanting to fit it as separate to the horn which I'm sure will be harder? but i don't want to loose that crappy 80s horn the Escort has.
someone mentioned the timing being built into the compressor? i thought that might be the case which means i wouldn't be able to alter it to fire all 5? just think that would sound great.
fred
WTF has happened to all the Vennies?
May 23, 2014 21:14:52 GMT
If you want dixie horns, you will need a decent sized compressor the ones they come with (Off fleabay) run out of breath, Always wanted a BIG Train horn, but you need 24 volt running rather like lorries use it can be done, just need the right sized big ass compressor running off 12 volt hows that work then sinse the timing for the notes is built into the compressor that comes with them ? for legal matters..seperate "off road use only" switch should do it I have had a few off the shelf dixie air horns, (I like em) and every one the compressor provided runs out of air half way through its the size of the compressor which you need to address, more air pushed through the longer you can hold the horn! Mine with the one they came with kinda sounded like a record player on 45 - then flicked to 33 it just faded out mid way if you get my utterly useless explanation Although I could be wrong, I always brought the cheapest set being a bit of an Arkwright
Last Edit: May 23, 2014 21:17:53 GMT by fred
'79 Cossie ran Cortina - Sold
2000 Fozzer 2.0 turbo snow beast
'85 Opel Manta GSI - Sold
03 A class Mercedes
Looking for a FD Ventora - Anyone?
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Dixie / Air HornToolsnTrack
@overdrive
Club Retro Rides Member 134
Klaxons are totally legal. Having witnessed the court based red faced traffic cop that got that wrong, believe me, a Klaxon can be used as a horn...
I used to have one of those klaxons on an old vw and passed mots no probs. Another vw was treated to one of those daft tarzan/wolf whistle various noises gadget....mot time and my actual horn decided to pack up...mot guy just used said gadget and said that as long as there was an audible warning it was okay
cjhillman
May 27, 2014 17:29:22 GMT
Did you get this working in the end? What does it sound like? Thinking about buying one the same..
jaswh
I'm sure it was in an 80's Bentley Turbo R there was a switch and you could select either a high or low tone. Technically then that's illegal as the options were either/or not both together? That said it had been Quentin Wilson's car at one point so all sorts could have been hooky!
2001 vauxhall corsa 1972 VW Beetle 1986 Ford Capri Laser1999 BMW E36 323i Touring 1991 Volvo 940 estate 2002 Mazda 323f 2.0 sport 2016 Mercedes Sprinter 1999 nissan almera 1.4 1995 lexus gs300 1995 lexus ls400 1975 bmw 1602 fiat punto 2003 ford fiesta something else...
Just saying ... hasn't Kev got one? I see your Godfather, and give you The Good The Bad and The Ugly
Roof mounted lights aren't legal for road use. You are SUPPOSED to have some sort of circuit that means they can only be operated when stationary. Well what about something similar for Dixie horns - maybe a relay linked to oil pressure switch so the horns will only sound if engine not running. Then you could have an override switch to they would work with engine running at shows, off road, private events etc.
Paul H
In Germany, it's legal to have more than one horn, as long as they sound all together. Melodies are illegal. Legal compressors have one air outlet, and the air is distributed by Y-shaped pieces. Melody compressors are bigger, they have a small transmission inside which drives a slotted metal disc, which turns slower than the compressor. They have 4 or 5 outlets (depending on the melody), one for each horn. When the metal disc rotates, the slots open always one hole at a time, so the melody is played. Quality horns come from Italy, the brands are Fiamm, Stebel and Fisa.
VIP
They aren't legal for UK road use so that is probably the reason why difficult to find. Strictly per "the letter of the law", as below, unless fire, ambulance or Police vehicle it's even illegal to have them fitted but doubt you'd get caught unless using such on public road. Regulations 37.4, and 99.4 Construction and use regulations. PNLD references. D2574 & D2576 37.4. No Motor vehicle shall be fitted with a bell, gong, siren or two tone horn unless it is for fire, ambulance or police purposes. 99.4. No person shall sound or cause to be sounded a bell, gong, siren or two tone horn, fitted or otherwise carried on a vehicle (Whether stationary or not) Paul H That part of the RTA is to prevent idiots impersonating emergency vehicles, and refer specifically to sounds which would traditionally be emitted by such a vehicle, such as a bell/gong, siren, or 'nee-naw' two-tone horn. It does NOT cover dual-tone horns (most car horns these days are dual-tone, my brand new up! has one listed as an optional extra!), nor does it cover musical horns/chimes. With decent defence you would negate any charge brought against you in respect of an alleged offence, of course it does not prevent any nuisance time caused by an officer ignorant or poorly educated in the Law.
