May 24, 2014 17:28:50 GMT
Hello wonder if anyone has had a similar problem to me
Rebuilt my 1600 crossflow mains shells rings First ran showed good oil pressure light went out (independent systems) 500 miles running it in, pulling into the car park noticed oil light just came on had a quick glance at the oil pressure and nothing, Changed oil pump to a old one I know was good, still no pressure Changed the sump and pick up pipe (no good) Removed the adapter block I had for the oil pressure sender so it was just the original light sender in the block still no good!! I the took that sender out blew down with airline and light went out 99% sure it's not switches!
So I then striped the engine again mains shells have little to no wear!! I didn't touch the cam bearings and as I said was perfect for 500miles was at low rpm when the light came on!
There is more where on the roocker shaft around where the rockers sit, but not enough to loose oil pressure I wouldn't imagine
Only thing I can think is I've got a cracked oil way, is there common areas on the crossflow engines to crack because I can't physically see anywhere, or has anyone had anything similar?
Can you get a block pressure tested?
Any help will be greatly appreciated as I am tottaly stumped cheers
rodney
May 24, 2014 18:20:15 GMT
ive had this on a cvh and a r5gtt engine , are the shells the correct size?? has the crank ever had a regrind?,.
May 24, 2014 20:11:04 GMT
Crank has been re ground and has been bored out I've double checked I've fitted the correct shells the ones I removed wasn't that bad of nick
v8ian
May 24, 2014 20:19:32 GMT
What Oil are you using?? Did you use silicon mastic on the rebuild? correct filter?
May 24, 2014 20:22:51 GMT
I've just looked at the cam bearings again and it looks like the oil way is Beeing half covered? The oil way runs between the camshaft bearing and 1 of the mains, it doesn't look like it's rotated and I wouldn't know how it could but could this be the problem? I would imagine this would increase the oil pressure
Cheers
May 24, 2014 20:26:47 GMT
Used classic motor oil think 5w 40, I have wondered I did use silicone on the sump gasket there wasn't that much access when I just removed the sump but guess it wouldn't take allot would it! Yes oil filter were definately right it was giving good pressures for 500 miles
v8ian
May 24, 2014 20:41:04 GMT
5/40w is wrong!!!!, should be 20/50, crossflows are a oil volume rather than oil pressure engine, so pressure is not as essential as you would think, I don't thing 20 psi hot at tick over for a fresh engine on 20/50 is unusual on a fresh engine. I don't think synthetic or semi syn is good for a new, old style engine either, it glazes the bores
May 24, 2014 20:48:31 GMT
Just went out and checked it is Morris classic oil 20w 50 I used, after I put the new sump and pick up pipe on I changed the oil so wouldn't be oil deteriated to much
May 24, 2014 20:49:47 GMT
Ow it is semi-synthetic
v8ian
May 24, 2014 21:25:08 GMT
That wont immediately affect the bores, its mainly because the older style engines don't run nikasil or chrome bores, so you don't really need to bed rings in, on the x flow, first the rings are a lot thicker and apply less pressure on the bores and with the superior lubrication of semi syn, it prevents the rings bedding in against the cast bores. I know you said you changed the pickup pipe and sump, Not knowing what pickup pipe you are using, is there any chance the pickup is blocked by sitting too close to the sump, that can be the case wit the saucer type filters on the bottom of the Pickup, and if the sump gets pushed up on a speed bump or something it can close the gap between the sump and pipe, I always used to weld a 6mm nut to the edge of the pick-up just to prevent this, Is it worth taking the cover off the pump and inspecting the gears?possibly check the clearences
May 24, 2014 23:25:10 GMT
Oil pressure relief valve stuck or sticking open?
v8ian
Another thought or two, Thrust bearing undersize/dropped out/not fitted did you put a smear of something around the top of the pickup pipe when fitting, Can you fit a temporary capillary oil gauge even if you just tape it to the top of the scuttle so you can see it and go for a drive? . Pessimistic this time, crank badly machined, or block not thoroughly cleaned and blocked oil way,
May 25, 2014 11:30:04 GMT
Have you changed the oil filter again since the trouble started? If the filter has become blocked or seriously obstructed and does not have an internal relief valve, most of the oil will be recirculating through the pump relief valve and oil pressure will be low to nil....
Nick
May 25, 2014 16:45:59 GMT
I took the sump pick up pipe oil pump and the filter off of a 1300 crossflow I was running last year in it so I know that's all sweet, when I rebuilt it I put a new oil pump on it I did check the cover, didn't check any clearances tho, I didn't put any oil or anything when I put the pick up pipe in! But again was sweet for 500 miles
May 25, 2014 16:54:05 GMT
When I done the rebuild every oil way was blown through with clean oil, new thrust bearings were fitted std ones came out so that's what I put in,
May 25, 2014 18:32:22 GMT
Oil light and gauge sharing the same sender? easy and cheap swap
May 25, 2014 21:40:11 GMT
Long time since I did a xflow, but from memory, the main shells have a drilled & a non drilled, are they right way round ?
May 25, 2014 21:54:44 GMT
There was a aluminium block Whitch allowed you to use both original sensor for light and the new sender to recieve oil pressure, both lost at the same time, I even removed the Ali block and just had the oringinal sensor in and still no pressure Mains were definately correct yes there are 2 holes in there with only 1 Beeing used as a oil way Think the only option I got is to clean re assemble the bottom end, crank it and see if I get oil through the top of the block, if not it's scrap
