stonio
May 30, 2014 17:56:20 GMT
HELP... advice please, when removing my old Track Rod Ends they were very rusted so l had to drill them out, this has led to the hole now being 2 big for the new replacement Track Rod Thread (Yes they are the correct parts) The hole also has to be tapered, i have been told to weld up the hole and re-drill them :/ I was wondering could l weld in some sort of sleeve (pipe) to form a new hole.?? These parts are very rare for my Skoda so finding another pair will be very difficult, any advice much appreciated
shin2chin
You could but you would only be able to weld the front face which wouldn't be as strong as just filling the hole with weld and drilling and tapping.
Club RR Member Number: 160
Steering Arm..Rich
@foxmcintyre
Club Retro Rides Member 160
You could but you would only be able to weld the front face which wouldn't be as strong as just filling the hole with weld and drilling and tapping. It won't need tapping, it's the tapered hole for the TRE to sit in. I assume..
v8ian
We Need pictures.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
barty
sounds like a machine shop job to get the correct taper ?
93fxdl
Enter your message here...
May 31, 2014 11:15:49 GMT
Depending on level of damage, and availability of parts, would it be possible to go up a size of tre and ream to suit ? Or convert to rose joints. It may be possible to make an adaptor similar to the ones used on beetle ball joints Ttfn Glenn
