Hi all. Yesterday going up hill in the ginetta my af gauge read lean and the engine stuggled. I knew this was going to be an issue but have never got around to sorting it. Its due to my tank being flat bottomed. plan is to fit a lower additional tank below..... So I'm thinking drop feed would work well amd all willebe fine in the world. just looking for others to confirm really cheers all :-) Chris
omega
what about fitting a swirl pot instead of a tank?
So basically across where the filter is currently, I looked at swirl pots but they just wont work in the space available. Rectangular with a top 8mm entry and 8mm bottom. Will also add to my overall capacity
rodney
have 1 made up , it only needs to hold a liter of fuel,.
omega
but if you fit another tank you will be increasing capacity anyway or do you need more capacity? I would also check your electrics under there,that tape dosnt look good nor does the routing of the cable it as it looks like it could rub and fracture and petrol vapours and sparks don't go well together.
