Jun 22, 2014 12:53:34 GMT
Hi Guys, I have a 1975 vauxhall magnum coupe an am thinking about fitting a 5 speed box of some description. I've looked at droopsnoot zf boxs when they pop up but they tend to go for silly money! the last one in excess of £1600! has anyone converted any other 5spd box to fit a 2300? cheers Mac
Jun 22, 2014 15:27:08 GMT
Mate had a VX2300 GLS with 5 speed box - is that the same as the droopsnoop ?
Paul H
matty2300
Red ones go faster!
Jun 23, 2014 14:50:09 GMT
5 speed in a Magnum, options are a ford type 9 gearbox with an adapter plate (if you can find/make one) a really hugely expensive ZF (price is so high because the Sunbeam boys like busting them) a notoriously weak overdrive box, which still leaves you with the less-than-fabulous synchros in the old vaux box.. or The toyota w58 gearbox as fitted to - 1982–1985 Toyota Celica (US) 1982–1986 Toyota MK 2 Celica Supra 1986–1992 Toyota MK 3 non-turbo Supra 1993–1998 Toyota MK 4 non-turbo Supra 1986 Toyota Cressida 1986 Toyota Soarer 1982–1992 Lotus Excel 1992–1997 Lexus SC300 1998–2005 Lexus IS300 5 speed will fit on the vauxhall slant four engine, using the Lotus Excel bellhousing - its got a Hydraulic clutch which will mean some mods to convert from the cable I'ts well known as a strong transmission capable of withstanding a LOT more torques than the old Vauxhall lump is going to put through it, its availiable with several different tail extensions for adjusting the gear lever position, I'ts modern feeling with a smooth change, and you can find em at the scrappy if you're lucky - lotus excel bellhousings can be bought at www.lotusbits.com/I've not yet done the conversion myself but i have the 'box and bellhousing waiting in my parts pile If you ask over on the "droop snoot group" they should be able to help, people have done this conversion and there was a write up in their club newsletter about a year or so ago.. -Matty-
Last Edit: Jun 23, 2014 14:51:40 GMT by matty2300
2002 Saab 93 - Daily 1972 Vauxhall Firenza Sport SL - in storage 1978 Vauxhall Magnum - PROJECT 1993 Vauxhall Cavalier 2.0 GLS - DEAD 1994 Vauxhall Astra 1.4 LS - DEAD 1999 Saab 93 2.0 SE - DEAD 1999 Mercedes W202/C200 - DEAD
Rob M
Club RR Member Number: 41
Jun 23, 2014 15:45:04 GMT
I recently met a chap who fitted a 6 speed Lexus box to the standard engine in a Commer. Anything is possible!!!!!
Jun 23, 2014 21:07:35 GMT
could an R380 or LT77 not be fitted? Common as muck, strong as brick poop-house
Jun 25, 2014 16:52:27 GMT
Very interesting thanks guys :0) thats given me plenty of options to think about. I'm liking the sound of the toyota set up
