mexicansteve
South West
Club RR Member Number: 31
Pinto oil blowingmexicansteve
@mexicansteve
Club Retro Rides Member 31
2.0 pinto, skimmed about 4 months ago, is running fine except that at consistent higher rpm (about 3.5k) its blowing oil out of the filler cap. Not a vast amount but enough to concern me. Any ideas on a solution?
sent from the '70's
BeQuietandDrive
1989 Bedford Astra Van
93fxdl
Enter your message here...
First clean all the breather system, give the one way valve on the side of the block special attention, if the breathing continues, fix a baffle inside the rocker cover to prevent oil drops splashing onto the filler cap. Ttfn Glenn
mexicansteve
South West
@mexicansteve
Thanks matey. Baffle it is.
sent from the '70's
BeQuietandDrive
