Set of 4 mk4 astra coupe wheels with 215 40 17 tyres
Pair of goodyears I think on the front, will check this evening around 4mm
One continental Conti sport 3 on the back and a Wanli (same tread as conti)around 5mm
Curbing and corrosion on all wheels, but look of from a distance
Pick up only
Also 1nr Astra Mk5 sri 17 inch wheel with same size tyre but not sealed, leak on rim (delflated) use as spare only £40
Call or text Ian 0 7 7 4 9 0 2 7 3 2 5
pick up only from Wirral CH61
Breaking the car so if you would like anything let me know
Pick up only
