Hi all
Can any body recommend (or tell an idiot) what to put on my air line to catch moisture?
I have a compressor that is in my workshop, this has a machine mart combined pressure regulator, oiler and moisture bottle thingy on it. However i have to run an airline to the front of my house about 200 feet to the car i am working on. I leave this flexable pipe out all year and when i went to use it the other day i thought i had water powered tools for about 5 mins...HELP!!!
Geoff
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
Get a reel and pack the hose away when your not using it
Can you run the pipe up or down hill with a second water trap at the low end? Or ive seem some where close to the end (house in your case) they have a vertical rise with a water tap at the bottom feed in low level and take off higher up about 1.5m that apparently works well.
Get a reel and pack the hose away when your not using it Yep that would be the intelligent thing to do, i guess:)
Can you run the pipe up or down hill with a second water trap at the low end? Or ive seem some where close to the end (house in your case) they have a vertical rise with a water tap at the bottom feed in low level and take off higher up about 1.5m that apparently works well. Thanks! i think swampy has it about right, i'm just lazy and its a pain to store!
Jul 10, 2014 16:18:50 GMT
Easiest way to solve this problem is to buy a blow gun, if you've not already got one. They're v.cheap and actually very handy as well. When working with the long hose after not having touched it for a while just use the blow gun to clear the water and then switch to whatever tool you wanted to use.
Jul 11, 2014 13:40:44 GMT
Being lazy is an underrated talent! How about one of these?
Koos
