Hi guys, bought off a friend with intention to put one on the Granada but there are more bigger and pressing projects that need to be done and I cannot see myself using these in the foreseeable future. Pair of Holley 390CFM four barrel carbs. The cleaner of the two has had new gaskets and bushes put in by the previous owner. Choke unit was removed to fit the electronic choke unit but the choke shaft and plate itself aren't present. 2nd unit is for spares or repairs really. Secondary butterflies are seized closed but the vacuum works. Standard choke unit on it if you wish to fit the choke parts onto the better carb of the 2 (I can do this for you if you wish). Electronic unit is NIP with all the fixings brackets and the linkage, these retail for around £70 on their own. Also comes with the original carb linkage which needs painting but is perfectly usable. Please note that as I haven't been able to test these so I cannot guarantee their functionality but you will be able to get one working carb out of the 2.
Ideal conversion for Stags, SD1s etc. with adaptor plates widely available.
For extra cost, I can countersink the butterflies and use countersunk bolts for additional airflow.
Looking for £150 posted within UK.
Thanks,
Ahmet
Thanks,
Ahmet
