Hi guys looking for a 7/9 series estate is most preferable got an 850 which ive just driven to rome and back and she hasn't missed a beat.
The car is a 96 850 2.5 (10v) manual in white
The good,
Fully serviced all filters replaced (air,oil,fuel,spark plugs)
Timing belt & Aux belt Replaced Genuine volvo Timing belt & gates aux belt.
Brake fluid changed.
Rear pads changed.
Front pads were changed recently before.
Rear exhaust box from middle flange replace genuine volvo.
New radiator & obviously fresh coolant.
Tyres are decent back two are at about 3mm which are the lowest on car.
5 Alloys
Heated seats
sunroof
Clutch done 20-25k ago
wind deflectors
long Mot (9-10 months)
Seems to be an up spec model with lots of extras on it and has done me well I'm sure there is a few things i have missed that were replaced.
The bad
Heater fan resistor packed in needs a new resistor unit (common fault)
Offside front wing is starting to rust around the arch but not bad enough that i would consider replacing.
slight blemishes around car what you'd expect i suppose from an 18 year old car
Leaning tower of pisa stuck to bonnet
In all honesty if it doesnt go I'm not bothered as its such a good car, but i have the itch for an older boxier RWD volvo that i can throw some more of my money at and i thought it would be worth asking on here before i delve to deeply in to ebay/gumtree.
Obviously stickers would be removed before hand (unless buyer/swapper wanted them on for whatever reason)
The good,
Rear pads changed.
5 Alloys
Heated seats
sunroof
wind deflectors
The bad
