barty
Aug 11, 2014 12:57:07 GMT
Driving to work today and for no reason it just stopped, engine cut out. Starter turns over a bit faster now but wont start. Was on my own so couldnt check too much so left it and will return later today. anyone got any ideas ?. was running fine with no missfire got plenty of fuel. what would make it turn over faster now but not fire up? are these cam belt or chain ??
VIP
Aug 11, 2014 13:37:16 GMT
Faster turning of the starter = lack of mechanical resistance. You've either snapped a cambelt or lost compression.
barty
Aug 11, 2014 14:29:50 GMT
yeah that was my thinking thats why i asked if it was a belt or chain
VIP
Aug 11, 2014 14:48:23 GMT
Last Edit: Aug 11, 2014 14:50:02 GMT by VIP
barty
Aug 11, 2014 19:16:00 GMT
oh well was thinking about sticking a new belt on and trying it but sounds like ill be wasting my time....anyone got a 1 ltr micra engine ??
barty
Aug 11, 2014 19:20:52 GMT
how easy are they to do an engine swap , not thinking about going bigger just a straight engine swap and has anyone got one. Might scrap it if i cant find a local engine
pork
Aug 11, 2014 20:30:45 GMT
The cg10/13 engine from the k11 bolts straight onto the k10 gearbox, just need a preface lift cg10 flywheel and redo the driver side engine mount Either way, really really easy to work on these micras
barty
thanks to everyone for the advise, looks like there is no point in just replacing the belt and hope for the best then lol. might try to look for a second hand head then do the work as its in not bad nick and it is taxed and tested
Aug 12, 2014 17:38:41 GMT
Before jumping to conclusions take the rocker cover off and turn the engine over. Do the rockers/cam move? Did the timing mark for tdc and see if the number one cylinders valves are being actuated at the right time.
barty
Aug 12, 2014 19:08:07 GMT
i took the dizzy cap off and turned the engine over and nothing turned so assumed it was the cam belt, could it be anything else ?
pork
Aug 12, 2014 19:56:21 GMT
If your gunna source a new head , try get a ma12 head and a good skim, has a better inlet port design
