Aug 12, 2014 23:39:24 GMT
My C230 hasn't been used for a month, put a new battery on yesterday and took it for a spin and it was hesitant under acceleration. Put some injector cleaner into the tank and took it for another drive today, but it's still hesitant and now feels lumpy. COuld anyone suggest any possible causes? It was fine before it was laid up for a month.
Thanks
wu11ie
Aug 12, 2014 23:41:38 GMT
How much fuel was in it ?, could be a build up of moisture in the fuel tank ?
Aug 12, 2014 23:55:10 GMT
Just under 1/4 of a tank was left in it.
wu11ie
I'd try changing the fuel filter and if you can drain the tank and give it a rinse with fresh fuel, i'd also check the vacuum pipes and MAF, see if anything's maybe perished or come loose due to not being in use.
Last Edit: Aug 13, 2014 2:01:47 GMT by wu11ie
