Our newly purchased Datsun cherry is running very rough and revs have to be slowly built up. The idle and cruising is erratic and low on power and car is smokey, especially after sitting for a while. Took the plugs out and they show it is running very rich. Gave the carb a blow through (with a by cycle pump ) and nothing appears to be blocked.
The mixture screw does very little to the revs. Spark looks strong. Muffler is shot so replacing that soon. On a side note, what gains would I see fitting a larger stainless exhaust?
What else should I look at?
Also, found this wheel bolt that someone has put in manifold. Anyone know what should go in here and if it could be affecting the mixture?
