Hi,
I'm trying to help someone fix an error code / running issue
The car is a Fiat Seicento with multipoint 1108cc FIRE engine
The car is rough at idle and shows code P0505 which is the Idle Air Control Valve Circuit
He has tried two more throttle body units which show the same error
He has tried another ecu / immobiliser / key and the engine wouldn't start and showed code U1600 which is immobiliser fault
I have supplied an alternative ecu set and the same U1600 code comes up
I don't know if there are any other things to try?
The battery was disconnected whilst the ECUs were swapped. I think he is going to reconnect the replacment setup and leave it before trying to start, to see if the car gets used to ?!?!
Hopefully someone has some info on these ecu systems (
Thanks
James
Thanks
James
