A genuine Oak green valver
Some on here know the build, but here's an overview...
Bare shell rebuild, all rust cut out and plates welded in properly, treated with bilt hamber products prior to paint and then cavities pumped with dinitrol or bilt hamber cavity waxes and underside and arches given a hefty coat of underbody seal.
Drivetrain/running gear reconditioned and built up with new bushes and bearings, brake calipers overhauled and fitted with new lines throughout, new discs front and rear, uprated 285mm G60 front brake setup.
Sat on standard G60 steels wheels up front and 1 inch wider Bullet ‘Sixtys’ at the back
Rebuilt engine and gearbox fitted in re-sprayed engine bay
Saggy roof lining removed and recovered, interior in good condition, all bolsters and seats in good condition. Rubber sound deadening fitted under carpets
Complete re-spray including door shuts and engine bay followed with five coats of 2K lacquer.
New bits fitted
Fuel pump
Fuel filter
Copper brakelines throughout
All flexi brake lines, goodridge up front
Front and rear discs
Valve stem seals
Waterpump, cambelt and tensioner
Brake pads
Handbrake cable
Refurbed alternator, new bearings, brushes and slip ring assembly
Decent Bosch 4 year battery
Cambelt and aux belts
Two new lower ball joints
Starter motor
Sunroof seal
Wheel centre caps
Uprated parts
ABF engine
G60 285mm discs and calipers
Stainless four branch exhaust manifold
Complete Scorpion stainless steel exhaust system
K&N oil filter
Performance panel air filter
50mm inlet manifold
Koni adjustable front coilovers,
Polybushed rack, front wishbones, front cross member and rear beam
I bought this car eighteen months ago in a dismantled state, and intended to just slap it back together, but I tend to get too attached to these projects to just do half a job – it was obvious I’d gone past ‘just a quick job’ when I bought a plating tank to replate fasteners and brackets.
I finished the car back in mid August 2014, passed the MOT with a couple of advisories – now rectified - and then gave it a 500 mile shakedown run up to VW Action.
Since then I have done maybe 100 miles in it, she stays in the garage, dry and well clear of car park dingers.
She is an absolute hoot to drive, the coilovers are not too harsh, anyone who has driven a Mk2 GTI will know what a great drivers car they are, this one has the added bonus of a fair few more horses under the bonnet as well.
I’m only selling because I need a van to carry my kayaks and the kids about in, I’d wreck the Golf pretty quick
I appreciate that the price is strong for a mk2 but think it reflects the amount of work that has gone into the car to ensure it is properly sorted.
Model: Golf Mk2
Year: 1990
Mileage: 158K? about 1K since full nut and bolt resto
Tax: Feb 2015
MOT: Aug 2015
Pics: yes
Price: £3000
Contact details: 07989 seven1188four
