Hi all
The idea is to ditch the factory linkage set up which operates twin SU carbs and upgrade to a cable type system for a more responsive pedal feel. I have been looking at ideas of how to attach the cable onto the SU carbs and came across the set up below which essentially uses a throttle type of pulley system. I tried the usual weber, dellorto, Motorsport oriented shops but was unable to locate a similar kit. Anyone out there who knows where I can buy one ?
Harada sells these as part of a complete solution for twin or triple carb set up.
If all fails, the bracket is easy to fabricate and I could possible modify a S14 throttle pulley
