Though I've tackled many automotive tasks, I've never actually changed a wheel bearing and my Saab ng900 needs one changed.
I'm ok with the stripping down the suspension but am bothered about getting the bearing out and the new one in. Various websites say you either do or don't need a press and are little help. As the good people of RR are a practical lot, I thought I'd seek your advice.
If I do need a press and anyone Bolton/Bury ish has the facilities to swap the bearing once the strut is off, in exchange for beer vouchers, please let me know.
Jaguar S-Type 3.0 SE
Oct 14, 2014 10:47:25 GMT
Whether you need a press or not depends on the type of wheel bearing, and therefore the car it's going on. Tapered roller bearings, as found on the front of old rear-wheel-drive cars (and the rear of old front-wheel-drive cars) can be installed with simple hand tools. Cars which have independent suspension on the driven axle (front or rear) will usually have double-row ball bearings. Some are pressed directly into the knuckle, which need to be pressed out and the new ones pressed in. More modern cars will tend to have bearings which are sealed permanently into the hub, which therefore must be unbolted and replaced whole. These are the most expensive type to replace, but also the easiest by far. Based on a quick google, your Saab has the press-in double-row ball bearing type, so therefore you will require a press to change them.
Oct 14, 2014 12:32:50 GMT
most back street tyre places will have a press and swap it over for cheap if you take in the dismantled strut
Oct 14, 2014 19:04:44 GMT
most back street tyre places will have a press and swap it over for cheap if you take in the dismantled strut I think that's the best plan. There's an MG specialist round the corner from my house who would probably welcome a break from welding.
Iain
Oct 15, 2014 13:18:35 GMT
You can do the press-in bearings in a big vice with various sized sockets and old bearing races. And knock out the old hub from the bearing with a big hammer.
All easier in a press of course.
Oct 15, 2014 14:41:17 GMT
just take it all apart go down a friendly local mechanic and get them to press it in for beer money. less stress for you and jobs jobbed - I had to do exactly the same for my current new daily
Oct 15, 2014 18:54:40 GMT
My local MG specialist will do it for £20. Sorted.
