Need to have a ignition switched power feed to new gauges and fan controller in the dash.
Triumph provide 2 terminals for this on the back of the ignition switch, unfortunately both are in use!
Can anyone suggest a neat, safe way of adding one (or more) 12v feeds to this terminal? The only thing that springs to my mind are piggyback crimps or Sotchlocks!
Have seen some common bus fuse-boxes on Ebay Fusebox, but the 12v feed is by a uninsulated ring terminal, which I'm not happy about!
Is there anything else?
Thanks.
Thanks.
