After some ideas from the educated in this field, or really anyone with half a clue!!
Have an e36 cab which originally had a 2.8 m52 fitted. Lots of cooling issues, a bodged ripped off head repair later and I give up and shove a known good 325i m50 motor in it.
Starts runs and drives fine, but have emissions issues.
This is due to a number of factors namely different lambada on 328's (Titania instead of zirconia or vice versa) and the fact there's two of them and the fact I thought it was good to solder in the loom which apparently doesn't work due to the lambda using the air gap in the cable to get the O2 reference.
No idea if that's really true.
Anyway.
I need to fit in the 325 lambda (single, much more basic affair) into the downpipe. Problem is in the now binned 325 downpipes I'm certain there was a 2 into 1 pipe and the lambda sat in there, the 328 has two separate pipes the length of the system and no obvious join point as the cats even look separate.
Option 1:I can mount the new lambda on either one of the old 328 pre threaded holes but will this then cause it to mess up the ecu as the readings are only from one bank of cylinders as the manifold is 2 piece?
Or
Option 2: Could I fit two lambdas into the two pipes and crimp the appropriate wires together to split the signal as such and get a balanced reading across both manifolds hence the ecu should then read the average of the two??
Or am I worrying about nothing and the one sensor fitted to one downpipes will do a perfectly adequate job?
The car is not going to be used in anger or do huge mileages but of course it needs to pass an mot etc and not do 12mpg!!!
Thanks in advance.
Anyway.
Or
Thanks in advance.
