sowen
Club RR Member Number: 24
Good to meet you too Plain looking series/defender wheels look amazing banded, I have a set of defender rostyles and wondered how they would band... Amazingly according to Sowen's picture! OMG!! I just googled and found this, I take it these are banded too HNNNNGG Hi, no, they look like forward control or 1 ton wheels. And they go for serious money when they come up for sale. Colin Another vote for forward control rims, I doubt they are particularly wide so not worth pursuing by most off-roaders, best left for the collectors to argue over. That's close to the look I want on my series
sowen
Nov 11, 2014 22:38:12 GMT
bryn
I had a set of late model Defender Rostyles banded by James P last year and fitted them to my early Range Rover, they looked ace! Big fan of that!
Volvo, Buggy, Discovery and an old tractor.
I got my Rostyles back from the blasters, the centres have now been welded to the rims and I've made a start prepping and priming them Oooooh. Me likey. You have renewed my faith in them now.
sowen
Nov 13, 2014 10:29:24 GMT
Oooooh. Me likey. You have renewed my faith in them now. I finished priming the rim wells last night and put the first coat of white on the faces, should have them fully painted by the weekend, and given a week or so for the paint to cure they'll be ready for tyres and fitting in two weeks or so Just got to check clearance against the wonky front corner bumper caps on my Disco....
Nov 13, 2014 10:41:52 GMT
i've got a set of rostyles going spare (need refurbing)...just taking up space as i've got the vogue alloys too. my rangey currently
Nov 13, 2014 12:32:47 GMT
Iv'e had about three and a half sets done by James now very good!!!
Nov 14, 2014 13:23:55 GMT
i've got a set of rostyles going spare (need refurbing)...just taking up space as i've got the vogue alloys too. my rangey currently How much are you looking for them?
Nov 15, 2014 17:07:09 GMT
Not the ones in the pics. It's another set with scabby tyres....£10 each.
Matt
Nov 17, 2014 12:50:50 GMT
Are you able to post them?
sowen
Nov 23, 2014 14:57:52 GMT
Nov 27, 2014 16:14:14 GMT
LOVING THEM!!!!!!!!!! You have convinced me now. Watch this space, although mine will probably be gloss black.
sowen
Nov 27, 2014 18:46:42 GMT
LOVING THEM!!!!!!!!!! You have convinced me now. Watch this space, although mine will probably be gloss black. You mean you weren't convinced before? Mine are now dirty grey/brown from less than a week of commuting!
Dec 14, 2014 17:00:53 GMT
Plain looking series/defender wheels look amazing banded, I have a set of defender rostyles and wondered how they would band... Amazingly according to Sowen's picture! OMG!! I just googled and found this, I take it these are banded too HNNNNGG Hi, no, they look like forward control or 1 ton wheels. And they go for serious money when they come up for sale. Colin Hi, My name is daan, I joined this board today, after I saw a pic of my truck on here by chance. Yes, I had my wheels banded. They are based on TD5 defender wheels, which have a welded centre. I used to run modular wheels, but it didn't suit the car. Modular wheels are 7x16 with a 8mm offset. Landrover wheels are 5.5x16 with a 33 mm offset. To get to the same offset as a modular (or 8 spoke) wheel, it needs banding by 2"; endresult is a 7.5x16 landrover wheel with 8mm offset, like a modular wheel. I had the work done by a dutch specialist, . There are several options in the uk, but main reason for choosing him is that he can weld beads on the rim to turn a tube type wheel into a tubeless wheel. The beads are quite important to me because I need to keep the tyres on the wheel at low pressures while offroading. I still run a tube for this reason as well. velgenverbreden also happened to be located in the village where my parents live (I am dutch, but live in the uk) Tyre size is a 35x10.5x16 simex tyre, with a 10:00x16 tube. finished result, with valve protector:
rims only, see the band in the wheel well and the welded beads on the rim:
The 1 ton rim is only 6.5" wide and has an offset of 20 mm, only about 1/2" further outboard from a standard land rover wheel. They are also very expensive, as mentioned. Hope that helps, Daan
Last Edit: Dec 14, 2014 18:38:17 GMT by dieselmax
I love the little valve protector. That's a cool little detail. I may steal that idea. I snaffled these locally from the bay of Evil for £20 Gonna drop them off at Essex Banded Wheels after payday.
