Nov 13, 2014 13:17:00 GMT
This has been happening for a while now, the car will start fine for days then will just refuse to start. Turns over as usual but just wont fire up. If I leave it for maybe a couple of hours or until the next day she'll fire up fine again? Any ideas on what to look at? It's almost like it's flooding, can k jet injection cars flood? Many thanks for any input
Nov 13, 2014 22:49:58 GMT
When you say the cars seems to have flooded does the engine actually turn over quite swiftly? Leaky injectors could be one cause and they are quite simple to check on a 924 non Turbo . OTOH, does the fuel pump prime when you start the car from cold? I do not know if they are like the Escorts but my 944 did prime the fuel pump. Try possibly going from no. 1 to 2 a couple of times to see if the car does prime the pump. IIRC fuel filters are simple enough to change on them .
Nov 16, 2014 17:57:29 GMT
hi there
I suspect if the thermo time switch / cold start injector playing up.
Chers - mike
Nov 16, 2014 21:54:46 GMT
Generally speaking they will still fire up without the cold start injector ; many K-Jetronic cars run with them disconnected with no ill effects.
Nov 17, 2014 15:25:19 GMT
Replaced the old cold start injector with no change. New battery but still turns over quite slowly...maybe starter motor wiring needs looking at? Just annoying that it is so intermittent put new seals on all the injectors but guess there could be a leak there somewhere?
Nov 17, 2014 15:44:40 GMT
Check that both pumps (in tank and external) are pumping when cranking, they don't come on with the ignition on the first stage. Fuel pump relays can go faulty, often a quick dab of the soldering iron at each joint sorts them.
Have you got a full list of things you have replaced since getting the car?
'73 Commer Campervan under full restoration, '83 VW T25 Doka under partial restoration to become rolling project, '04 Saab 9-3 Vector Sport modified and certainly not finished...
ed5000
Nov 17, 2014 16:15:40 GMT
That sounds like the fuel pump relay to me. Mine did the same thing. Cold starts were very intermittent. Once I fitted the new relay it was fine.
Nov 28, 2014 11:09:32 GMT
I had a very similar fault with my 1986 728i. After a lot of head scratching it finally turned out to be the direct live feed wire from the battery + post to the fuel pump relay. On these cars there is a direct feed bypassing the fusebox. The nut on the battery post was a bit loose resulting in intermittant power supply to the relay. One twist of the spanner sorted it.
Current: 1986/C 735i E23 Polaris silver 1985/B 735i E23 Cosmos blue 1994/M 730i E38 Sorrent blue 2001/Y 530i E39 Slate green
Previously owned: 1986/C 728i E23 Polaris silver 1989/G 325i E30 Malachite green 1982/Y 735i E23 Opal green 1986/C 528i E28 Cosmos black 1986/C 728i E23 Arctic blue and various other horrors/classics
Nov 28, 2014 15:33:07 GMT
From the above - check the earthing points! If the starter is turning slowly, attach a jump lead from the body of the starter to the engine.
shin2chin
Nov 29, 2014 20:04:56 GMT
Mine was like this recently, found I was getting condensation in the dizzy cap. Just gave everything (plugs, leads, dizzy cap) a good clean and wd40. Starts on the 1st turn now. Also worth checking your aux air valve is working, they can stick open/closed.
Nov 30, 2014 15:53:44 GMT
Thanks for the replies chaps, could well be a battery wiring issue, freshly charged and she generally turns 1st turn of the key
