Need to clear out this lot from various spares for cars I no longer own.
Would be interested in swapping for mk2 golf bits - i need a dsf door, a psr door in atlas grey, a gti alternator, repair panels for floor edges, 5 door outer sill repair panels both sides, 5 door headliner in black for a sunroof.
mk1
£30 the lot or:
mk1 golf dash switches: headlight, hazard x2, fog & heated rear window? £3ea
GTI steering wheel, also fits '75 on bug column £20
image by flat4fanatic, on Flickr
front seat uprights in beige from a 5 door £10.
Pics: www.flickr.com/photos/65648255@N04/sets/72157633163840125/
rhs & lhs door mirrors Glass cracked in both but otherwise complete £10pair or £15 for all 3
grab handle £2
mk2 golf
Interior:
Dash clocks not gti, 66k miles £10
Column (inner) £5
Various other little bits of trim
Door lock mechanisms x4 £3ea
Parcel shelf support brackets/trays 1x exc. cond, 1 cracked £15
Mk2 golf seat pull wires for 2 door £3ea
Body
1408562908714 by flat4fanatic, on Flickr
lexus style rear lights mk2 golf £25
momo steering wheel and boss £50 (pic to follow)
eyebrow spoiler for single headlights £10
Single headlight debadged grill £15
Roof / gutter trim 5 door d/s vgc £15
d/s front arch liner £5ea
Front subframe £20
slam panel £10
Petrol flap £2
Door outer trims x 4 £10
Side indicators £5 pair
Pair parcel shelf supports 1x broken clip £15
Lots of little bits and bobs, door rods etc
Mechanical
petrol tank £10
Engine bits
came off a pb code engine :
Gti drilled air box £5
Exhaust manifold (bolt type) £20
Digifant inlet manifold £10
Cambelt cover (2 bits) £10
Cam, crank, water pump pulleys £10 the lot
Rocker cover spreader bars £2 ea
Plastic coolant hose to block connectors £3ea
Coolant pipes – various £2ea
Pb code ecu (not tested) £10
oil cooler (the bit the filter screws onto) £5
K&N filter - not sure what it's off - maybe a mk2 carb or a mk3 golf? £10
slam panel £10
mk3
£70 the lot or:
dsf and psr, doors with glass, rust free £10 each
Electric window mechanisms psf & psr (no d/s) £10 each
Bonnet, rust free £10
GTI front lights £15 pair
dash £5
washer bottle and pump 5
mint parcel shelf £15
mastercylinder and servo £10
loads of dash switches/ e/w switches, relays etc
front grill with badge £5
front arch splash guards 5ea
front slam panel £5
Radiator £10
Blower motor £3
Seatbelts £5ea
vented calipers £20 pair
front wheelarch splash guards £5ea
Alloys x4 2 vg tyres 185/65 r14, 2 not £40, ok for a daily / winter wheels
factory fit sunroof – tilt & slide fully working – motor, glass, switch £20
Couple of boxes of trim bits, dash switches, boot carpet,
www.flickr.com/photos/65648255@N04/8620741338/
some pics: www.flickr.com/photos/65648255@N04/sets/72157633163840125/
mk4 3 door GTI
£100 the lot or:
body
2x doors both vgc, inc glass and lock mechs 20ea
Hatch (someone's started trying to smooth it) 10
Electric heated door mirrors with blue tint glass 10ea
Clear side indicators 5 pair
lockset - ecu, ignition switch, door locks boot lock £25
interior
various relays, fuse box etc
in dash single cd player and radio etc £20
Glovebox 15
Steering wheel with airbag £20
Column switches £10
Hazard and hazard switches 2ea
Double push out cup holder 10
Dash inc p/s airbag. vgc £10
Clocks £5 (mileage unknown)
Headlight switch £5
Door e/w looms 5ea
headliner vvgc 15
Seat belts with pretensioners £5ea
Rear seats with cupboard, black with headrests £10
Sun visors 3
mechanical/engine
Aircon compressor 10
Starter 10
Ecu £10
Fuse box & relays 5
Alternator 15
Washer bottle 3
Radiator and twin fans 15
Ac rad 5
Air box 5
Gbox 30
front gti calipers £15pair
New down pipe and cat £40
Fuel pump/sender 10
Fuel flap 5
Horns 5pr
petrol flap switch £2
Gti cylinder head complete with cam £30
Loads of water pipes from engine
Engine bay wiring loom complete
Power steering pump 10
ABS pump/module 10
various relays etc
photos on flick here: www.flickr.com/photos/65648255@N04/sets/72157648607978575/
15 inch alloys x4, good tread £40
drivers door £20 by flat4fanatic, on Flickr
p/s door £20 by flat4fanatic, on Flickr
Haynes manuals / books: £5 each
Passat 96-00 petrol & diesel
Mk1 golf/jetta (74-84), golf cab (80-85), scirocco (74-82)
Mk2 golf/jetta 84-92
Would be interested in swapping for mk2 golf bits - i need dsf door, psr door in atlas grey gti alternator, repair panel for floors, 5 door sill repair panels, 5 door headliner.
Collect from near coventry preferred but could post small bits or you can arrange a courier to collect if you like.
mk1
£30 the lot or:
grab handle £2
mk2 golf
Interior:
Column (inner) £5
Body
Front subframe £20
slam panel £10
Petrol flap £2
Mechanical
petrol tank £10
Engine bits
slam panel £10
mk3
£70 the lot or:
dash £5
front slam panel £5
Radiator £10
Blower motor £3
Seatbelts £5ea
mk4 3 door GTI
£100 the lot or:
body
interior
Glovebox 15
Column switches £10
Headlight switch £5
Door e/w looms 5ea
headliner vvgc 15
Sun visors 3
mechanical/engine
Starter 10
Ecu £10
Fuse box & relays 5
Alternator 15
Washer bottle 3
Ac rad 5
Air box 5
Gbox 30
Fuel pump/sender 10
Fuel flap 5
Horns 5pr
ABS pump/module 10
various relays etc
