Nov 30, 2014 17:39:09 GMT
Hi all, I've got a small issue that I can't seem to get my head round. I've got the drivers side front hub etc off my saab so its up on blocks in that area. No problem there, but where i lift it up to work on it and then lower it back down onto the blocks it has skipped sideways a bit. So over the last month or so the car has shifted on the drive and I can no longer open the garage door to get to my tools etc easily.
The drive is too rough to put a jack under it and shove it back over and I don't really fancy jacking it up and pushing it over as it lowers and crossing my fingers it lands in the right spot.
I'm sure there's an embarrassingly simple way that I'm missing to put it square again. Any ideas ?
Nov 30, 2014 17:46:31 GMT
Just jack it up all the way, on the opposite side to where you have been jacking from, an then drop it down, repeat as much as needed. It should then pull the car back over that way into its original position.
Last Edit: Nov 30, 2014 17:47:48 GMT by scott15
Nov 30, 2014 17:55:22 GMT
Could you temporary refit the hub and wheel ?
Thanks for the suggestions fellas. I tried jacking it up from the other side, same thing happened, it wants to start going over when the passenger side tire hits the ground, I suppose where the tire hits the ground on the outside edge of the tire first. Compo: Yeh I can do, but I'm still quite a learner and it will take me half a day to get the wishbones back on and the hub and all the other bits. Was trying to find a quick cheat. Did think I might have to just get on and do it the long way though. Thanks for your thoughts chaps.
Put a piece of wood under the Jack. Drag it, carefully, on the wood.
Hi Elmo, just signed in to update that I'd managed to straighten it up. I was going to try it the way you suggested, then I got mad cause it was cold and dark and sh*t outside. So I put a big lump of wood onder the chassis rail, turned the wheels facing the right way, wedged my feet against the garage wall and pushed and shoved it over / back. Job done. Thanks for the suggestion though, it made me get out there to have a go.
