Firstly, thank you for your help with the previous electrical problem, the final piece of the MOT fail is the offside indicator. It just doesn't want to come on. The rear one comes on. I did some investigation and came to the conclusion it was a dodgy connection in the wire between the loom and the indicator unit. This was because it I plugged a bulb directly into the wire in the loom it worked.
Replaced that wire and still nothing, checked the wire out of the loom and now nothing there too.
I've decided (and feel fee to tell me I'm wrong!) It's either the indicator stalk (could be as that's where the sidelight problem was) or a fault in the wire somewhere in the loom....
Can I bypass the loom and run a wire directly to the indictor from the fusebox or somewhere else?
Again, many thanks
Again, many thanks
