J1MMY
Dec 17, 2014 22:49:24 GMT
Bit rusty (no pun intended) as it's been a while but....
From memory, a capri 2" lowering spring drops a mk2 cortina by 3". How much would it lower a corsair? This is assuming the a Corsair uses a mk2 (can't remember if mk1 is the same) Cortina spring?
I guess what I'm trying to get at is will a capri spring fit a corsair and drop it by the same increments? D'oh.
Your opinion is invalid, I've seen your wife.
Here you go, 2" rs2000 (think same as capri) on my mk1. 1600e leaf springs on back (no blocks). Mk1 cortina and corsair suspensions are the same, the MK2 front struts and springs are different.
1966 MK1 Cortina 1971 Hillman Super Imp 1985 Volvo 360 GLEi 1986 Volvo 340 1.7 1990 Mercedes 190e 2.0 1993 Peugeot 205 STDT
J1MMY
Mk1 cortina and corsair suspensions are the same, the MK2 front struts and springs are different. That's confusing as I've fitted capri springs in a mk2 before as you have in your mk1 (RS escort as capri are the same, reacquainted myself with the Burton part numbers) yet you say they're different? Argh lol
Dec 18, 2014 10:07:35 GMT
Dec 19, 2014 11:36:02 GMT
^ they make lots of different poundage rates in the lowering springs
I'd Just bite the bullet and make some coilovers from the legs and set it how you want it to look
Last Edit: Dec 19, 2014 11:37:34 GMT by fordperv
Dec 19, 2014 11:47:02 GMT
Yep that's good advice, I really want mine 3" now but I can't be bothered changing them again so will just stay like this.
J1MMY
Dec 19, 2014 13:53:54 GMT
Yep that's good advice, I really want mine 3" now but I can't be bothered changing them again so will just stay like this. Last time I messed with a Cortina I got Gaz coilover made up but the time before I used 145lb Capri springs with shorter strut inserts (but can't remember for the life of me where I got them from). I just want a simple spring swap for now so will go with whatever fits the Corsair.
Dec 20, 2014 12:25:09 GMT
I'm just using standard inserts, with the springs stainless cable tied to the cups, it seems okay. You can also use volvo 240 inserts and top mounts. There are AVO aftermarket shocks etc but I think they are quite pricey.
