Jan 25, 2015 17:01:59 GMT
Hello! A quick question to see if I have worked it our right (measurements are rough) I currently have the Capri JPS alloy 5.5J +19ET Looking for new wheels and looked at these pictured below which are 6J +10 ET Some hopefully with my understanding they will fit okay and fill the arch a tad more but won't cause any issues touching the suspension as its close on the 185/60... cars lowered 2-3inch ![](http://i732.photobucket.com/albums/ww329/seaneylad/Screenshot_2015-01-25-16-08-39.png) ![](http://i732.photobucket.com/albums/ww329/seaneylad/IMAG0904_1.jpg)
Jan 25, 2015 19:58:14 GMT
Hi, no I don't think that's right. The stated wheel width is the bead width, there is the rim and the tyre "bulge" to consider as well. Use this site to enter you tyre and wheel dimensions for your present and proposed ones, it will then tell you what you get and also to find what you need. - www.rimsntires.com/specspro.jsp Colin
wheel size and et help/adviceDez
@dez
Club Retro Rides Member 34
Jan 25, 2015 20:40:40 GMT
yeah, what youve done isnt right. a 6" wheel is actually 7" wide overall. the rest looks right though, even if you have worked it out in a slightly odd way.
it helps if you know what ET means- its short for Einpresstiefe in german, which basically means 'insertion depth'. its how far past the hub centreline the wheel is 'inserted' into the car, or moved out if the number is a negative value. if the number is 0, the wheel is spaced evenly around the hub face- half behind it, half in front.
so each wheel will actually 'stick out' 12-13mm more than what you have calculated.
Last Edit: Jan 25, 2015 20:47:01 GMT by Dez
Hi, no I don't think that's right. The stated wheel width is the bead width, there is the rim and the tyre "bulge" to consider as well. Use this site to enter you tyre and wheel dimensions for your present and proposed ones, it will then tell you what you get and also to find what you need. - www.rimsntires.com/specspro.jsp Colin Thanks That link is really helpful
yeah, what youve done isnt right. a 6" wheel is actually 7" wide overall. the rest looks right though, even if you have worked it out in a slightly odd way. it helps if you know what ET means- its short for Einpresstiefe in german, which basically means 'insertion depth'. its how far past the hub centreline the wheel is 'inserted' into the car, or moved out if the number is a negative value. if the number is 0, the wheel is spaced evenly around the hub face- half behind it, half in front. so each wheel will actually 'stick out' 12-13mm more than what you have calculated. Cheers, back to work out what will fit, need to make sure it it clears my coilovers and wont catch on my arch lowered. Thanks for info
Jan 26, 2015 10:36:04 GMT
Jan 26, 2015 14:05:23 GMT
Thanks, done both to double check! Think ET 10 or ET 16 are the best solution for me, more poke towards arch and similar for suspension clearence on the HUB side. ET10 ![](http://i732.photobucket.com/albums/ww329/seaneylad/Untitled.png) ![](http://i732.photobucket.com/albums/ww329/seaneylad/Untitled2.png) ![](http://i732.photobucket.com/albums/ww329/seaneylad/Untitled3.png) ET16 ![](http://i732.photobucket.com/albums/ww329/seaneylad/Untitled1.png) ![](http://i732.photobucket.com/albums/ww329/seaneylad/Untitled5.png) ![](http://i732.photobucket.com/albums/ww329/seaneylad/Untitled6.png)
sparkyt
selling stuff
Jan 27, 2015 23:17:54 GMT
Yes they will be spot on
