mdw
Jan 27, 2015 19:49:51 GMT
I've just got a e30 BMW with a suspected head gasket problem. However I'm not sure it has gone?
There's mayo under the cap that didn't clear after a 70mile drive It never got hot, the temp sat at about a third all the way home. A friend has done a test on the coolant but it showed no sign of combustion gases
What's people's thoughts has the head gasket gone or not?
1989 VW Caddy 1993 BMW 316/2.5 Touring 1985 BMW 316 (e30) 1984 BMW 316 (e21) 1992 VW Passat 1984 Porsche 924 - SOLD 1985 Volvo 340 GL - disfigured Now cubed 1990 BMW 318i - Sold 1989 BMW 535i SE - executive express SOLD
Jan 27, 2015 19:53:01 GMT
Do a compression test .
Jan 27, 2015 20:18:48 GMT
If it drives fine for 70 miles I wouldn't suspect the headgasket, more like a slightly stuck open thermostat not allowing the engine to warm enough to boil the combustion condensation out of the oil
Don't worry about the HG until you see mayo on the dipstick IMO.
Jan 27, 2015 20:21:34 GMT
Mayo under the cap doesn't mean anything.. moister will gather in the cap if it been driven slowly or short distances alot.. If you have done a sniff test and that was ok then you fine
mdw
Jan 27, 2015 20:51:17 GMT
I would have thought the mayo would go after a long run. What cobblers said makes sense though so I've order a new thermostat and see what happens!
bortaf
Jan 27, 2015 21:05:42 GMT
IME the mayo wont go, you need to wipe it off and then see if it comes back is the water level dropping? if not i'd say it's just condensation and not coolant ?
R.I.P photobucket
Jan 28, 2015 15:19:27 GMT
HI, as Bortaf says you need to physically remove it, take the cover off as well if necessary. There is water in there and it will just keep on evaporating and condensing.
Colin
Jan 28, 2015 16:02:05 GMT
if the sniffer says okay and no water loss or overheating then it sounds okay
whip the rocker cover off and clean it up along with any breather hoses etc , then a fresh oil change and keep an eye on things every trip until you can trust it
taurus
Jan 28, 2015 17:22:18 GMT
Check oil and coolant levels, check the water dripping from the exhaust - if it's clear fine, if it's coolant coloured then coolant is getting into the combustion chambers.
By the sounds of it there isn't a problem.
