It was a while ago but I think it was only one full coil but it could have possibly been two. Start with one and see how you go. Is yours the 1.3 8v? The exhaust runs under the sump and will be your lowest point. I used to catch mine pulling off my drive and the occasional speed bump. Other than that and rolling the rear arches to squeeze the banded steels on I had no issues with the suspension Yep 14'' banded steels. The corolla is 4x100 so theres a huge selection of wheels available oh and golf vr6 front splitter has the perfect profile for the curved edges of the front bumper but will need trimming in the centre to fit [br hi yea it's the 1.3 8v...iv cut 1 and half off the front and 1 coil of the rears.just gotta heat the very last coil so it sits in the cup properly... did you ever have any problems with hot starting???
I did, when it was warm sometimes it would just crank and crank then finally fire. Changing the dizzy and points sorted mine I think. It was a few years ago now so I'm a bit sketchy on the details but basically a good engine service should see you right
Maximum signature image height = 80pixels
I did, when it was warm sometimes it would just crank and crank then finally fire. Changing the dizzy and points sorted mine I think. It was a few years ago now so I'm a bit sketchy on the details but basically a good engine service should see you right no worries have been chasing the hot start for ages but never found anyone with a corolla that speaks English lol..so gives me somewhere else to look at I cut my springs yesterday..cut 1 and half off the front and 1 of the rear and heated the very last coil so it sits in the seat properly
I found the same problem with info, everything on the net is in places like malaysia
get some pics of the car up!!
Not really got many pics lol will upload the few I have
and heated the very last coil so it sits in the seat properly I'd say ensure you source a spare pair of springs idc as heating is going to have altered the properties of the metal so it's no longer "springy" and therefore don't be surprised if it breaks at that point ! Might also be part of the problem you are having with ride over bumps.
Trying to source some coilovers so won't be on ther too long
