Hi
I have a pair of bolt on hubcentric 25mm Eibach Pro System 7 spacers for sale.
They are 4x100 with a centre bore of 60.1 so will fit all 4 stud Renaults.
Supplied with M12 x 1.5 bolts with shallow heads to bolt the spacer to the wheel and then you use your normal wheel bolts to bolt the wheels to the spacer.
They will also fit 4 stud VWs but you'll need spigot rings and will only work for you if your wheels have cb of 60.1 or bigger.
They're on eBay with 99p start and no reserve.
pages.ebay.com/link/?nav=item.view&alt=web&id=121573323358
Cheers
Phil
Cheers
Phil
