I'm just trying to get my head around this idea, so please don't shoot me down as I'm still trying to learn about it all.
If I were to get an ECU, wiring, sensors and whatever else I need from one car, could I 'simply' transfer it to another car of a different make but the same cylinder size? I have a Porsche 924 with a 2l NA engine and K jet injection which is in pretty much need of total replacement. This is more than i'm willing to pay for new and all the secondhand bits I acquire seem to be dead/on their way out. Is there any reason why I can't get an ECU setup from another car with a 2L engine and swap it all over? I know there will be the fabrication work to mount up the sensors, etc, but that aside would it actually work straight off once hooked up? If not then what exactly would prevent it from doing so?
Now I know the obvious answer would be to go with Megasquirt, and logical people do that but I'm tight fisted (I don't have that sort of money spare currently and i'm sure I can find a car to sabotage the parts I need off for not much money) and I enjoy a challenge to some degree. I seem to recall Saab made an ECU system that was supposedly easily home tuneable (Trionic 8?). Are there any Stock ECUs that are possible to DIY tune if I would need to? Also if I did this sort of conversion, would it be fairly simple for me to wire in a Megasquirt ECU later on down the line as all the sensors will be largely in place?
Cheers in advance for any help.
