I have a 1996 Toyota Carib 4x4 automatic. It has recently started making a clonking noise (coming from the back) when I take my foot off the gas. This used to only happen when I changed down into 2nd or 1st but now happens when I'm in D or OD.
Should I be worried/robbing a bank?
Cheers.
Have you checked the rubbers on the propshaft could be worn
Not yet. I'm ignoring the car and hoping the noise will go away. That usually works.
So could be the rear propshaft?
barty
turn the radoi up a bit !!! got the same problem with my freelander but after a good look round it looks like the rear diff mounts are worn, will be replacing them on monday so ill get back to let you know if this has cured the problem, of course yours may not have the same mounts as a freelander
Not yet. I'm ignoring the car and hoping the noise will go away. That usually works. So could be the rear propshaft? I belive there is rubber bushings at the propshaft joints that can wear so I'd have a gander at them first
So could be the rear propshaft?[/quote] I belive there is rubber bushings at the propshaft joints that can wear so I'd have a gander at them first [/quote]
That sounds less horrifically expensive. In that case, I'll get underneath and have a shuftie. I've had the car about 4 months and not got dirty yet so it was about time for something to happen......
So could be the rear propshaft? I belive there is rubber bushings at the propshaft joints that can wear so I'd have a gander at them first [/quote] That sounds less horrifically expensive. In that case, I'll get underneath and have a shuftie. I've had the car about 4 months and not got dirty yet so it was about time for something to happen......[/quote] No if it is the bushing they won't be that much and if u can do the labour yourself
