I am in need of some desperate help here, purely due to my lack of experience.
I had a warning light come up on my dash of my early dord ranger truck and I have no idea what it means. My google searching has yielded no results (probably because searching ranger in Google bombards you with the U.S. model) and am in need of help.
The light started intermittently. It would come on if coming into a sharp corner with speed, and if it stayed on it would turn itself off if you went around a round about.
Problem is I have no idea what the light means.
Here is the light in question.
I've checked the oil level, just under the F mark on the dip stick, checked for oil leaks, changed the oil and filters, coolant also appears ok, it may be but over full but I've never added any in my ownership so it surely can't be that, there are also no coolant leaks and it's never overheated.
Can anyone make any suggestions? Seems stupid to be stumped because you don't understand a damn symbol.
